21 - 35 of 35 Posts
vag com is great, but now i don't know what else to do with it. got it yesterday and did the following today, video in motion, ambient lighting, remote windows and sunroof, battery level indicator, disabled amber lights, full brightness on drl while parking lights are on, adjusted level of drl when headlights are on to 35, default for adaptive drive changed, drl does not turn off when blinkers are on. anything else anyone can think of?
The video-in-motion thing... did you have to buy extra stuff to actually make it play dvd's? I don't know if mine is even capable of it... i doubt it as it doesn't say DVD anywhere.
It's an 09 S5 prestige
if you have nav with the dvd player, it works with nothing extra. just go to this link and it will explain everything you have to do for the video in motion: http://trick77.com/2009/07/18/enable-vim-tv-playback-vcds-vag-com-mmi/
for the other poster, here is a comprehensive list of mods for the vag com: http://a6retrofit.tripod.com/articles/a5vagcodes.html
this one has not yet been added to the a6retrofit page, but works great: http://www.a5oc.com/forums/showthre...s-drl-12001/index.html?t=12001&highlight=code
everything on here worked like a charm.
I have NAV, but i don't know if i have the DVD player or any of that other stuff... how do i check? That would be great if it already came with it...
Put a DVD in the media slot behind the drop down cover, if it plays you have a DVD player, if it doesn't you don't.:thumbsup:
VagCom for Mac
Has anyone used Vagcom with a Mac laptop (vs PC)?
I haven't done it personally, but based on threads posted in the Vag-Com forums on AudiWorld and/or Quattroworld it seems to work fine as a Windows application running under Boot Camp. Ross-Tech doesn't support it, so don't expect technnical help from them.
MattsS5,
Haven't tried what ChipB referred to either, that's why I'm using the good old windows laptop. Worth firing off a message to Ross-Tech to request Mac applications as in the long run it will throw a wider net for prospective customers!
i have a couple questions if anyone can help:
1. on a convertible, can you set this to allow the top to go down with the fob? and there is a code to make the seats have memory with the fob?
2. do i definitely need this if im converting my halogen headlights to the xenon/led drl setup?
yeah what Nino said... no problem using software via VMWare or Parallels
Of course not, running windows on a Mac via bootcamp or similar, is just the same as a "normal" windows pc.
But I don't wanna "infect" my Mac with windows, so please make a version for OSX. There's gotta be a market for that.
21 - 35 of 35 Posts
