1 - 2 of 2 Posts
Hi all am in bracknell berkshire I have tried a couple on via previous thread but unfortunately they don't have the cable at the mo. During my drive back at crimbo went thru a sodding huge puddle unavoidable due to traffic since airbag light has been on called aa out fault come up with b101b15 front passengers crash sensor .... I any help would be appreciated. 2009 a5 2.0 tdi
176842
There is a crash sensor mounted on the headlight mounting bracket that needs replacing. Fault code is pointing to the passenger side one so find a used sensor and replace it. Bumper will need to come off which is no big deal. You can try to remove it first and check water in the cable connectors first. But you will need a diagnostic tooo
l such as vcds to reset the fault code regardless if you only check wiring and or replace sensor.
1 - 2 of 2 Posts
