1 - 2 of 2 Posts
Hello
this will activate your 6.26.1 map
https://mega.nz/#!oJ4VWZJY!k-jwNKcD3mCEW311hqXBw7eFhHPKSrQu8HECtTu_HCc
procedure:
put the files to the root of a fat 32 formated sd card
turn on the mmi
wha it 5 minutes so that all of the internal parts of mmi is booted up
insert ss cart into sd slot 1
a message will appear on the display, the just push the main button once
the script will install it self
after that a new message will appear saying succes
pres again the main button
remove the sd card
reboot navi : setup+main button+ top right button
the navi will restart and the map will be unlocked
if the sd card is not recognized try another card , restart the navi, wait those 5 minutes so that navi is booted entirely.... eventuality it will recognize the script and unlock the map, neither did mine runned the script the first time but finally it did ... with another sd card... so try it out . it will not brick your navi but as always try at your own risk, and do not interrupt the procedure - the best way is to do this with engine running.
this will work only for mmi 3g high,
regards from liniaunu
1 - 2 of 2 Posts
