1 - 6 of 6 Posts
So just having the car 3 months, the Turn Signal/Parking light bulb is out? Is that even possible? Would the dealership fix this for me since it's practically a new car?
I know I can probably replace the bulb myself.. Has anyone changed out their turn signal/parking light bulb? Is it a hard process? A writeup on how would be great :) There seems to be no room to get in and pull out the bulb..
Well if anyone could help.. Thanks in advance!
Are you referring to the front or rear?
If you're referring to the front, then I'm somewhat confused when you call it a "turn signal/parking light bulb" because those are separate bulbs in the headlight housing on US spec cars. There's a bulb that actually blinks when you have your turn signal on, and then there's another bulb that lights up when your parking lights are on (the one behind the amber reflector).
The one of the front of the one behind the amber reflector that lights up when your parking lights are on.. is that an easy change?
You're right, there's no room to access the bulb. You will have to remove the headlight housing first. See this link for instructions and pics on how to remove the headlights. Once you get the headlight housing out, it's pretty straightforward to gain access to the bulb.
Take it to the dealer. You shouldn't have to fiddle with that. The car is brand new....
1 - 6 of 6 Posts
