1 - 1 of 1 Posts
Hi, ive discovered an oil leak from the vacuum pump and I‘ve spent a couple of hours today attempting to remove the unit, it’s not easy to access being infront of the bulkhead. I managed to remove the 3 nuts that hold it to the engine but its very difficult to move, I removed another 2 audi star shape nuts which connect the high pressure fuel pump to the vacuum pump but the unit won’t budge. There is a fuel line and some over bits I believe probably need removing but it got dark so gave up. Can anyone help with an Elsawin diagram or share any tips if you have done this job before.
Many thanks
1 - 1 of 1 Posts
