Transmission overheating driving in areas with traffic lights but on the highway it doesn't. Seems like the fan I thought but fans kick on when I checked them. Although they kick on but to me it doesn't blow enough. Is there any thing else that might create the overheating?
Manual or auto and if auto which box? And what tells u it is overheating?
Sounds like a dodgy thermostat on the tranny cooling and or pump. There is a coolant pump just near the bulkhead (firewall US speak). After a run, feel it, it should be vibrating/buzzing when working. Also low oil in the tranny can give overheats. Also if yours is the S tronic pre 2012/2013, then some of the common faults can give abnormal readings.
@SimonRoma - Manual boxes don't usually have temp monitoring. :)
Reactions: SimonRoma
