1 - 6 of 6 Posts
Hello,
It’s normal for a tiptronic transmission in manual mode, that i only be able to change from the first to the second gear after past 2.000rpm-2.500rpm?
Discussion Starter #2
Hello,
This information is very important for me, there is no one with a tiptronic (automatic transmission) that can help me?
Thanks again!
I’ve never had a tiptronic, only s-tronic, but 2k rpm for 1-2 upshift lower limit sounds reasonable to me in manual mode. Have to be honest, never tried manual mode in mine from a standing start, but I guess you’d need some revs before upshift?
Diesel or petrol?
The diesel won't change into 2nd gear until 2.250rpm when it is doing a DPF regen :)
Also my S5, DSG box, when the engine is cold, it doesn't like to change up to the next gear until after 2,000rpm. After a few miles it will change up at 1800rpm :)
Discussion Starter #6
I’ve never had a tiptronic, only a-tronic, but 2k rpm for 1-2 upshift lower limit sounds reasonable to me in manual mode. Have to be honest, never tried manual mode in mine from a standing start, but I guess you’d need some revs before upshift?
Hello, you are right.
1 - 6 of 6 Posts
