Well, I should have done this a long time ago! Here's my B8.5 S5 summarised up to date:
Aug 2018 the car was dropped off with 6k more miles than advertised. Slough Audi in England had to give me a cash sum or take the car back obviously... good start:
Had to go back for four wheel alignment and centering the steering wheel as it tracked all over the shot under heavy braking. Also a fault in the MMI needing an update.
It also then went back shortly after to try and sort the dead animal smell in the HVAC system. They found nothing.
So finally I started to enjoy the car, albeit without using aircon.
Firstly, because I have a soul, it must always be fundamentally necessary to lower the car and sort the stance out. So some H&R springs, 20mm and 25mm spacers and a morning wrenching:
I did at this point notice the rear beam was way out of whack.
Off she went back to Audi again...
Returned exactly the same told that its 6mm out, which is the limit of tolerances in the build. Told to deal with it and it cant be adjusted. Fantastic I felt like Audi really cared and valued my existence. Cheers guys.
...Tried to sell the car (luckily it didn't sell)...
Soon after, the famous leaking water waterpump bearing! Booked in to Audi again. 10 week lead in period and no courtesy car again. So, sod the disruptions and delay, changed the water waterpump for a genuine new part.
Turbulent 2 months but at least by then it was all sorted...
...at least I thought
