Hello,
I have an Audi A5 Sportback(2013) and i noticed today that, when it is in parking mode with air conditioning activated and with start-stop deactivated, and i try to open the door the car stopped alone, as i press on the ingnition off key.
I mention that i don t use the car for 2-3 weeks
And this behaviour don t occur every time. Only for 2 times i managed to get this behaviour today. In the other cases it works normally. (with no stops alone)
This could be due to not using the car for a long time(2-3 week) and the battery can be a bit discarched? Or ? Have you faced this problem so far? It is a normal behavior? Or?
Thank you!
It’s a safety feature so as not to leave it running unattended.mine does it👍🏼
this feature can be stopped with VCDS.
  1. select module 46 - Central Conv.
  2. Coding - 07 -- > Long Code Helper --> Byte 11
  3. change Bit 2 from "1" naar "0"
  4. press ESC, select Do-It
  1. slect module 46 - Central Conv.
  2. Coding - 07 -- > Long Code Helper --> Byte 15
  3. change the value "0F" into "00"
Reactions: SimonRoma and TonyP
