1 - 7 of 7 Posts
I have had a new 2009 S5 for about two weeks now. (It is realy cool - even my wife, who thought I was crazy for trading in the A6, is coming around after a couple of drives). Just put in my first new tank of gas, and was surprised that my gas gauge stuck, continuing to show nearly empty! Has anyone else experienced this?
I believe that this could be a known fault and a TSB has already been issued for those that suffer this problem.
About 8 weeks ago I had 3/4 of a tank and filled the car up (long journey) but was surprised to find that when I got back in the car it still showed only 3/4 full. The "range" on the DIS had gone up though.
Over the course of the trip the needle eventually dropped and on filling up again went back to showing a completely full tank. I haven't had a problem since then and had forgotten all about it until I saw this post.
happened to my s5 on my first ever full tank after goin up and down a very very steep mountain road the needle was stuck at 3/4 and 'range' display was still displaying same value after 60km. next day after restarting the car, everything is working fine ever since . . .
gas gauge fixed by pulling fuse
Just to close the loop on this, the TSB simply called for pulling the fuse. Apparently, sometimes during transport, the car is at a steep incline, and this causes the gas gauge to stop working and go into a mode where it registers empty. (I don't know why the gas gauge was working fine when I got the car, and only stopped working when I filled it up.) They reset the software by pulling the fuse. It took about 5 minutes once the service department figured out what it had to do, and then figured out which fuse to pull.
Hmm, despite several restarts, the gauge stayed on near empty, and the on-board computer showed range gradually reducing from 30 down to 0 miles. An overnight stop made no difference. However as an experiment I've just topped the tank up to full with £14 worth of diesel and the gauge went from zero to full. Unless the A5 has just done a 'Life on Mars' time travel thing back to early 80's fuel prices (that would be a neat trick) the fault seems to have been cured, though perhaps only temporarily. We'll see.
1 - 7 of 7 Posts
