Hi all. Sure it's been covered loads before but I cant find my answer. I'm upgrading the sub in the boot to a stealth in the rear side. The amp I have has hi level input but I also have a LOC to run RCAs. Which is preferred? I have the Audi sound system which gives me control of the sub through the mmi which I would like to be able to keep. Will this still work properly if I tap into the standard sub wires? With the LOC do how do i wire this to the 2 sub wires as it has 4, do i do a pair or + and pair of - or just 1 of each? If doing hi level input how would I wire this in also?
No help with your questions, but what sub/box are you planning to install?
Custom Fit subwoofer enclosure for Audi A5 Sportback 4047442079467 | eBay I've got a box similar to this although I found it about £20 cheaper. It still has the hole for the 12v socket to sit in as well which is good. For the sub I'm now trying to get a Alpine SWG-844 the 1 I purchased originally had a magnet that was too large for the box so clashed and wouldn't fit.
