1 - 6 of 6 Posts
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
4 Faults Found:
4327 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear
4698 - Function Restriction due to Faults in Other Modules
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -Intermittent - Not Confirmed - Tested Since Memory Clear
7150 - Please Check DTC Memory of Steering Wheel Electronics
P1698 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear
Address 08: Auto HVAC (J255) Labels: Redir Fail!
2 Faults Found:
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 3
Mileage: 114804 km
Time Indication: 0
Date: 2019.04.10
Time: 19:07:06
00713 - Centre Left Vent Positioning Motor (V110)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 120318 km
Time Indication: 0
Date: 2019.11.29
Time: 20:55:17
Freeze Frame:
Voltage: 14.30 V
Temperature: 23.0°C
Temperature: 3.0°C
Count: 10000
Count: 8295
Bin. Bits: 01000000
Bin. Bits: 10000001
Time: 196.00 s
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
1 Fault Found:
00003 - Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 114804 km
Time Indication: 0
Date: 2019.04.10
Time: 19:06:56
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb <---- Possibly RSNAV interfacing with the canbus
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 225
Mileage: 120547 km
Time Indication: 0
Date: 2019.12.03
Time: 02:29:01
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 10
Mileage: 120547 km
Time Indication: 0
Date: 2019.12.03
Time: 04:29:01
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.50 V
Count: 17
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
3 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 206
Mileage: 119787 km
Time Indication: 0
Date: 2019.11.12
Time: 16:18:42
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 226
Mileage: 119787 km
Time Indication: 0
Date: 2019.11.12
Time: 16:19:42
01565 - Luggage Compartment Light (W3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 29
Mileage: 114830 km
Time Indication: 0
Date: 2019.04.11
Time: 14:20:29
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
3 Faults Found:
02259 - Information Display and Control Head (Front) (J685)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 114804 km
Time Indication: 0
Date: 2019.04.10
Time: 19:07:26
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 10
Mileage: 116214 km
Time Indication: 0
Date: 2019.06.13
Time: 14:47:08
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 27
Mileage: 115469 km
Any help is much appreciated
Most of those are old faults. Have you cleared them to see which ones come back?
The fuel tank lock is a common anyways. Just needs a new motor and that will sort that out right away
1 - 6 of 6 Posts
