Sponsors
Body kits are inspired by the aerodynamic refinements in sedan racing. By careful sculpting of the body panels, and the addition of air dams, skirts, rear spoilers, ridges and diffusers, racers not only make their cars more aerodynamic. They also make them look very different. A body kit will transform your ride from anonymous to famous. We would like to discover few options for your Audi A5, which can help you easily transform it into real beast. By careful sculpting of the body panels, and the addition of air dams, skirts, rear spoilers, ridges and diffusers, racers not only make their cars more aerodynamic. They also make them look very different.
Duraflex is one of the Extreme Dimensions' product lines and it quickly rises toward the top of its industry. Duraflex is a range of aerodynamic body kits made from fiberglass. Because they are made from fiberglass, you can rely on them to be a little tougher, and longer lasting, than a standard body kit, and each one is designed to suit your specific vehicle. Get more information about this brand: Duraflex Body Kits, Custom Hoods, Fender Flares & Spoilers at CARiD.com
Duraflex® - S5 Look Side Skirts
Duraflex® - Eros Version 1 Side Skirts
What do you think about them?
Like the standard ones.
How do they mount?
Sponsors
Discussion Starter #5
Its normal that somebody likes the side skirts, and somebody doesn't - we appreciate any feedback. For someone this information can be useful.
Regarding the installation - all Extreme Dimensions parts require minor sanding, shaving, cutting, and/or filling prior to installation. They require professional installation. After the part is prepared, you need to mock it up, remove factory rocker panel if needed. Install the side skirt using screws on each end right where it wraps around the wheel well. This is the part where you might need to lift the car and take the wheels off. After completing installation check door clearances.
