I bought an Audi A5 in December with 96,000 miles on the clock and plan on servicing it this spring/summer (oil, oil filter, coolant, brake fluid, air filter etc)
The manual states: "The cooling system is filled for life at the factory, so the coolant does not need to be changed".
Should I change the coolant? If so, it states it uses G12++ so would G12+ be fine too (more readily available)?
As for the brake fluid, I normally change it every 2 years but noticed that it hasn't been changed for the last 4-5 years.
The manual does not state if I should use DOT 4 or DOT 4 ESP?
I only heard about ESP version yesterday on the internet. Should I just go with normal DOT 4?
