A friend of Jen asked me to carry out a detail on his Leon. He is more about power than showcasing his car, and you can tell...with over £8k spend on performance parts and the car producing over 360bhp its a rocket (been known to beat RS4's, Evo's etc). The owner does not wash the car himself and used a local car wash, resulting in the car being covered in Swirls. So since he was at Crail this weekend for a Vauxhall day, he wanted the car looking good and asked for a Swissvax detail (might have something to do with the Porsche Carrera 4S i detailed the day before).
Some pics on its arrival:
Discussion Starter · #2 ·
Initially the car was rinse and then the Alloys were cleaned with Bilberry Wheel Cleaner and the tyres and arches, door sills and petrol cap with APC
Then moved onto the Engine bay, applied APC and aggrigated it with a detailing brush to remove as much grime and oil as possible. Then the engine was run to allow to dry.
The car was then snowfoamed and rinsed, then washed (3 bucket method) using Swissvax Car Bath and rinsed. There was a lot of tar on the car so this was removed using Autosmart Tardis.
then the car was clayed using Swissvax Paint Rubber, washed again, rinsed again then dried using the blower and finished off using a waffle drying towel.
Checking the paint work, I found a consistancy of swirls all over it:
Initially I opted to correct using Swissvax Cleaner Fluid Pro, on a polishing pad, but this did not give the desired correction level, so opted for Fast Cut plus on a cutting pad,
then refined with Swissvax Cleaner Fluid Pro on a polishing pad. The results:
Discussion Starter · #3 · (Edited)
The paintwork was then cleansed using Swissvax Cleaner Fluid (Regular) and the same applied to the alloy wheels. once removed then Swissvax Mirage wax was used on the paint work,
Swissvax Autobahn on the alloys, Swissvax Pneu on the tyres, Swissvax Nano Express on the plastic trim, Swissvax Crystal on the windows, Swissvax Seal feed on the rubbers, Engine
bay was treated with Chermical Guys Silk Shine, interior was cleaned with APC and hoovered, Exhaust was treated with Swissvax Metal Polish and some steel wool.
The end results:
The owner was really happy with the result and noticed whilst cleaning the car and him helping out a little bit of OCD was coming out lol
Thanks for looking
Robert
