21 - 40 of 168 Posts
Discussion starter · #21 ·
just to let you guys know the MMI fully supports the SD card information listing all tracks, artists times etc. There was some confusion on another thread. Sorry if this is old information
Can anyone confirm whether the system will play apple format tracks i.e. itunes from the SD card or is it just windows media player files ?
...are you talking about iTunes purchases? If so are you a Mac or PC user? Whilst I'm not advocating circumventing any DRM I have been looking at a solution for Mac (OS-X) users as I have the same issue that I want to be able to use a load of iTunes purchased music via the SD card rather than CD's. There are only a few options (legal ones anyway) ... I can post details if you wish?
Discussion starter · #27 ·
Do not see the need for anyone to spec the CD disc changer. SD card is so much more convenient and a 2GB holds 34 albums
Hi Roswell,
Yes that's exactly what I'm talking about. I've got quite a lot of purchased music and would like to be able to play it on the SD cards. I'm a PC user btw.
Any details would be gratefully appreciated :)
I didnt spec it but it comes as standard with the nav option. However, 6 CDs full of MP3s still gives more capacity than a 2GB SD card as its closer to 4GB. With hindsight, I would have included the AMI and is the main option I regret leaving off.
Hey guys, I think there is another thread on this SD card question that I started a couple days ago without knowing about this one (sorry). My question was - for those of us with NAV, there is no SD card slot, so I asked if anyone had tried to use the glove comparment cable options (USB cable) to a hard drive or SD card adapter - TXcarguy responded to my thread saying YES it works fine. So, for those of us with no SD card slot, there is another solution. Order the optional USB connector cable and tuck your SD card in your glove compartment and you are ready to go. I am in the computer business so I plan to install a mega-size hard drive in the glovebox with ALL my songs - cool.
You should give the 4GB SD card a try.
USB -> hard drive works
Hi guys
I bought a portable hard drive (Formac 250GB) last week and can confirm that it works well in an S5 with the AMI -> mini USB cable. The cable was overpriced at £25 but I couldn't find anywhere other than an Audi dealer who had it! I believe there's a mini and "normal" USB so order carefully.
I've currently got around 7000 MP3 converted as Lame -V0--vbr-new (~230 kbps) on my HD and they sound very good through the B&O stereo. I've saved my MP3s as "Artist\Album\nn song name.mp3" where nn = track number, so it's easy to navigate the directory tree. The only (minor) things to note are:
- playback is NOT gapless (there's silence between one song and another) so mixes and albums where the songs merge/flow are interrupted (and this is with Lame gapless info, so it's the stereo not the MP3s)
- it can take a while (5-10 secs, guesstimate as haven't timed it) for the display to show files in a "full" directory (i.e. where there are many (hundreds) of files/subdirs) and become ready for input: this makes going "up" from album -> artist -> ALL artists a bit slow... you can get a "loading directory name x of y" type message sometimes. I think this too is an Audi issue as the HD on a PC shows a directory much more quickly.
Otherwise it's good (the above really are minor). The sound is transparent (i.e. the same, as you'd expect as this bitrate in a CAR!) compared to a normal CD and navigating the tree is easy (assuming you use some logic when setting it up). For under £100 (bought new, ignoring cost of AMI etc!) you can have a HUGE archive of music in your car which seems pretty good value compared to other systems I've used (e.g. Phatbox) in the past.
One other thing - I split my drive into two partitions and the stereo defaulted to the first partition on the drive (which has my MP3s, I guessed it would). I can't select partition 1 or 2. I also formatted as FAT32 (I would have to check the manual to see if NTFS/ext3 etc are supported).
Hope this helps someone!
Oaf
Finally had a chance to get out and purchase a 4GB and 8GB USB stick for my A5 sound system. I have a loaded A5 S-line with Navigation and 6-CD changer with NO SD-Card slot. My only option was to buy a $75 USB cable from Audi and place an SD card or USB stick in the glovebox. I'm happy to say that my system recognized both the 4GB and 8GB USB drive so I now have all my 3,554 songs from my computer loaded with tons of room on the USB drive to spare. Subdirectories are recognized as well so I can also sort my music by artist. NO MORE BURING CD's !!!!!!
Just to let you know that a 4gb card works fine I have a scan disk and a kingston both 4gb no problems :)
Good news! I bought non-SDHC 4GB cards and they don't work. So it'd be great if you could post a link (amazon or similar) to where you got your cards, or alternatively let us know exactly what it says on them (e.g. SDHC or not?)
Stoatie
Hehe ... this is where we find there are different software versions in the stereos, some of which support 4GB (and more?) and others which only support 2GB.
One for the geeks/nerds:
I'm was initially confused by the comments about SDHC as I was previously under the impression that anything over 2GB had to be SDHC so that the memory could be properly addressed. Not the case according to an article on Wikipedia (which in this case does seem trustworthy):
"Compatibility with 2 gigabyte and larger SD cards has been poor, due to the SD/MMC protocol's using a 32-bit address field denominated in bytes. The SDHC standard addresses this limitation by using 32-bit block addresses instead. Both SD and SDHC are traditionally accessed as 512-byte blocks on 512-byte boundaries, so the change to host software or firmware is minor but required. Before SDHC was standardized, various manufacturers "extended" the SD control block fields for their 2 GB and 4 GB cards in different ways. Those cards are incompatible with many SD and some SDHC devices, as they conform to neither standard. All SDHC readers work with standard SD cards."
