1 - 8 of 8 Posts
Just a reminder to S5 owners to keep an eye on your oil level, My car has covered around 3,500 miles now and is starting to drop on the dip stick (guessing around half a litre), too early to report useage but I will soon. I assume all S5's come with a pouch in the boot with a spare bottle of oil in it, but my dealer didn't explain to me about checking the level and while I know its good practice anyway, I'm sure some will forget....
Blade,
Sounds about right - my S4 (very similar engine) has always used about 0.5 litre every 4000 miles or so. I don't bother checking it that regularly, just wait for the sensor to warn me.
Do get your replacement oil through Audi though - they're about £1 per litre cheaper than Halfords for the same Mobil oil (and sometimes they don't charge me at all:D ). I also got caught out with an empty litre bottle in the boot last week and the Shell garage I stopped at charged me £16.45 for 1 litre of their fully synthetic 5W30 oil! Ouch!
You'll find the servicing a touch expensive as it needs about 12 litres for an oil change (from memory - might be a bit out on that) . Not cheap at around £11-£12 per litre! I'll check my last service receipt to see how much oil I was charged for, when I get a chance.
Thanks for that Blade,i am getting my S5 in december and am very interested in how many miles car will do before oil requires changing.
Mad,
I would assume it's the same servicing schedule as my S4 - about every 19k miles or so (depends how you drive it.)
I believe that the service interval sensor works off the oil condition, so it relies on the right type - 5W30 fully synthetic is your only choice, but there are several manufacturers available. Audi in the UK use Mobil. If you put any other oil in (even as a top-up), then you have to go to 10k mile service intervals (on the S4 anyway).
I've dug out my last service receipt and I was charged for 10.3 ltrs of oil at £99.99 plus VAT (17.5%).
Thanks Scratch ;)
1 - 8 of 8 Posts
