Hi All,
Need some help if thats ok.
I've got an Audi S5 2018, but someone has kindly hit the drivers wing mirror. Luckily the electrics, heater and glass is all interacted (once I've put it all back in). The bit that is damaged is this bit. >>>
177147
But I dont know what one is correct to replace.I think its a dynamic one as it doesn't blink on and off but glides left to right (or vice versa).
I've attached a pic of the car if that helps shed more light on what kind it would be etc.
177148
Thanks for your help in advance - and apologies if this may sound like a stupid question.
Cheers,
Paul
The part number should be written on the indicator. Either embossed into the plastic or on a sticker.
Now it’s back in one piece you can’t see that information. Call the dealer with the registration number and they will sell you the part. Probably won’t disclose the part number.
