176864
I've not long owned my s5 and just noticed this. Any ideas what the cable is for would be much appreciated.
connector looks like boot light and im pretty sure position of it is somewhere around there also
x3me...your spot on. Just went out to car and there is definitely no light in the boot. As am not sure what shape it is I dont know what to order from flea bay etc.. does anyone have an image of the orignal OEM one?
I think it's the same shape/design as the rear number plate light fitting. Or is it the puddle door lights? I changed them all at the same time & can't remember! :)
If you can slip that out - I think you push them to the right with a small flat blade screwdriver - then you can check if it fits.
Although to be honest I've found the Main Stealers very reasonable for small odds & ends & you will definitely get the right one if you order from them
