1 - 2 of 2 Posts
Hi all i retrofit Xenons and auto level controls to my audi A5 2013
since i have done this i have lost my front pdc and front windscreen washer
i have the front pdc displayed on the mmi screen but they just dont show how close i am to things
i have checked continuity on the washer wires and they are fine if i go in to measuring blocks i can see the when i pull the stalk that the signal is being received and i have checked the washer pump on another car and that's fine
i have changed my bcm1 from 8K0 907 063 DC to 8K0 907 063 DH i have also had component protection removed
can anyone help or point me in the right direction to start looking at things
Code:
Sunday,21,November,2021,17:00:58:23200
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
VCDS Version: 21.9.0.2
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WAUZZZ8T8DA048715   License Plate: 21-11-2021
Mileage: 181140km-112555mi   Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 55 56 5F 62 6C 72
VIN: WAUZZZ8T8DA048715   Mileage: 181140km-112555miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CJCB)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JP    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 2842
   Revision: 45H25---    CVN: DB1E9282
   Coding: 0A194012232401080000
   Shop #: WSC 40012 002 104857
   ASAM Dataset: EV_ECM20TDI01103L906018JP 003005
   ROD: EV_ECM20TDI01103L906018AC.rod
   VCID: 010E543F9053AA814E-8054
   VINID: 9D196AAAA2242144401081C1141C5DCFE6
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Revision: --------    Serial number: --------------
   Coding: 161544
   Shop #: WSC 06325 000 00000
   VCID: 0008513B9359A38941-8054
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 GB    HW: 8K0 907 064 FB
   Component: BCM2 2.0      H12 0633
   Revision: 00002001
   Coding: 03B44000000000000000
   VCID: 76E437E3C19D9D396B-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Component: FBSAUDIB8 IDG  H71 0083
   Serial number: 0512000083987008
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Component: J764 ELV MLB  H40 0046
   Serial number: 2312000281568013
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 AH    HW: 8K2 820 043 AH
   Component: KLIMA 3 ZONEN H04 0123
   Revision: D0000000    Serial number: 01131220120005
   Coding: 342402E000
   VCID: 6FEA0287BEC7ACF1A8-803A
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Component: BCM1 1.0      H16 0103
   Revision: 08016001    Serial number: 00001101019302
   Coding: 260000118034AFC00081400000001D0D001D020827090201000008000400020000000034000000
   Shop #: WSC 06325 123 12345
   VCID: 78F839DBCB89EB4979-802C
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 141212  H13 0080
   Serial number: SWF12120145338
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 20833742
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001012124109
   Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: F2780F56000000000001
1 Fault Found:
00156 - Control Circuit for Windshield Washer Pump
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 181143 km
                    Time Indication: 0
                    Date: 2021.11.21
                    Time: 16:56:16
Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H45 0610
   Serial number: 003KFD97B833
   Coding: 30533938363030303030554A305238543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003010
   ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
   VCID: 4898891BF3E95BC9C9-801C
   Crash sensor for side airbag: driver side:
   Serial number: 6334MSME75754B6BT
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 6344MSME75432E5CQ
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 6352QSME1A2910505
   Passenger side rear thorax airbag crash sensor:
   Serial number: 6362QSME78273B44O
   Crash sensor for front airbag: driver side:
   Serial number: 63732SME0B28384A2
   Crash sensor for front airbag: front passenger side:
   Serial number: 63832SME07280462T
Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130325001262
   Coding: 000016
   VCID: 4FAAA2071E878CF188-801A
   Component: E221 - MFL  H03 0004
Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 983 M    HW: 8T0 920 983 M
   Component: KOMBIINSTR.   H35 0556
   Revision: 00000000    Serial number: UUW27RJDD
   Coding: 33AD300002012600010000
   VCID: 4898891BFBE95BC9C9-801C
Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0055
   Revision: 1Y060027    Serial number: 2741Y12C2101F2
   Coding: 80CF07FF00
   VCID: 4A9CB313E5E5A9D9DF-801E
   Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
   Component: J367-BDMHella  H03 8041
   Serial number: 9361038801
   Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
   Component: J532_DCDCStab  H17 0042
   Serial number: 12354000711011200181
Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011502625001450005
   VCID: 56A45763215DFD394B-8002
Address 44: Steering Assist (J500)       Labels:| 8K0-909-144.clb
   Part No SW: 8K0 909 144 F    HW: 8K0 909 144 B
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0011131730
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008014
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3460CDEB9F61CF2995-8060
Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0300017325
   Coding: 013B062220B900C08320043680000000
   Subsystem 1 - Part No: 8K0 951 177
   Component: DWA-Sensor  H02 0040
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Coding: 011502225C01450005
   VCID: 55A6506F3C5BF62142-8000
Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000209472
   ASAM Dataset: EV_ParkiBrake 001027
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3878F9DB83092B49B9-806C
Address 55: Headlight Range        Labels: 8K0-907-357.clb
   Part No: 8K5 907 357 B
   Component: Dynamische LWR  H02 0010
   Revision: 00000001    Serial number:
   Coding: 0000001
   VCID: 397EFCDF7003324146-806C
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230L40C7578870
   Coding: 010003020100000001
   VCID: 2858299B5BA9BBC929-807C
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
   Component: H-BN-EU       H45 1036
   Revision: --------    Serial number: 206L-0C7511806
   Coding: 130101040006C1EF0180CF5E00000403E40000020000000000
   VCID: 428C9B33DDD5719917-8016
   Subsystem 1 - Part No: 8R0 060 884 HQ
   Component: EUR 2021  3201
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130L/0C2607696
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Component: E0380 Bedient  H02 0030
   Serial number: 00000001365606
   Subsystem 4 - Part No: 8R0 060 961 E
   Component: CD-Database  4949
1 Fault Found:
01043 - Control Module; Incorrect Software Version
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 181143 km
                    Time Indication: 0
                    Date: 2021.11.21
                    Time: 16:40:03
             Freeze Frame:
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000010
Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010402224001450005
   VCID: 59BE5C5F5043D24166-800C
Address 6C: Back-up Cam.        Labels: 8T0-907-441.clb
   Part No SW: 8T0 907 441 C    HW: 4L0 907 441 B
   Component: J772__Rearview      0040
   Revision: --H04---    Serial number: 525PA8-J0392UV
   Coding: 1022006
   VCID: 3878F9DB4B092B49B9-806C
Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-794.clb
   Component: TSG HR        H07 0304
End-------------------------(Elapsed Time: 03:54)--------------------------
1 - 2 of 2 Posts
