1 - 6 of 6 Posts
Does anyone know of a retrofit phone connection (cable or bluetooth) for the standard MMI?
Thanks,
Will almost certainly find what you need on www.navplus.us might even find someone in your area who has done it...
There is one thread Here
Jason
Thanks,
Yes you can.
By standard MMI do you mean navigation/MMI or radio Concert/Symphony? (Telephony is not available for Chorus radio.) Your specs don't seem to list navi, so I assume Concert/Symphony, which is not in fact "real" MMI but MMI-lookalike Audi Information System (AIS). Different technology, different components...
For the MMI/navigation Kufatec sells retrofit kits:
Just Bluetooth:
http://www.kufatec.de/shop/product_...ung-Bluetooth-Audi-A5-8T--Nur-Bluetooth-.html
Bluetooth and SIM Access Profile:
http://www.kufatec.de/shop/product_...di-Bluetooth-Autotelefon--mit-SAP--A5-B8.html
These require MOST fiber optics in the car, so only with MMI/navigation. For the radios, different technology and different components. I'm not sure retrofit kits are available yet, but your dealer might be able to help.
Thanks all. Looks like there is a solution. Ideally i'd want it to operate through the Phone option on the Audi Infotainment System..
Well, those Kufatec kits are original factory parts so they would be 100% identical to factory order. However, if you don't have the "real" MMI, you can't use those kits... I'm sure Kufatec will come out with a kit for non-MMI cars later.
For an explanation what is the difference between "real" MMI and the radio Concert/Symphony, see here:
http://www.geocities.com/a6retrofit/articles/a4a5realmmi.html
For many retro-fitting needs, this forum is good:
http://www.navplus.us/forums/
1 - 6 of 6 Posts
