Retrofit DAB
1692 Views 3 Replies 3 Participants Last post by  Booster
Anyone done this?
Is it possible and what are the costs please?
Did a search but you can't search for DAB as its too short :confused:
I think it works out around £500 :confused:
Kufatec
Booster: since your car has nav, it has MMI High, basically same system as in an 2004-2008 A6.
navplus.us MMI area is a good place to look for info on these:
http://www.navplus.us/forums/forumdisplay.php?f=32
DAB is easy to fit, to you need a DAB module, a new antenna array with DAB and whatever options you have now, TV etc. And the wiring harness. Takes approx 1 hour to fit
http://www.navplus.us/forums/showthread.php?t=8739&highlight=retrofit
http://www.navplus.us/forums/showthread.php?t=8946
You can probably find more info present there just by looking, or you could ask there.
I don't know if A5 has the DAB antenna standard. It might. Then you may need new antenna amplifiers, the DAB module and wiring.
You can get the parts here:
http://www.kufatec.de/shop/product_...plett-Set-digitales-Radio-DAB-Audi-A5-B8.html
Cheers for the info both. I think I might send a message to Craigyb!!
