1 - 1 of 1 Posts
I've preFL A5 (coupe) with really disgusting basic beige cloth seats. I decided to make an upgrade to leather seats and managed to find a whole set of all seats and side trims. New seats are from FL along with mechanical lumbar support control. (picture below for illustration purposes)
176895
Yesterday I finished replacing them and now my car won't shut up about 3 things (cleared DTCs couple of times):
Code:
Address 15: Airbags (J234) QML File: * 8K0-959-655.clb
   Software part number: 8K0,959,655 G AO: 8K0,959,655 G
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EFD03UKY3
   Encoding: 30313433363030303030554A304C38543053
   Workshop #: WSC 06 325 000 00000
   ASAM / ODX File Label: EV_AirbaECUVWAUDI010 003010
   ODX: EV_AirbaECUVWAUDI010_003_AU48.odx
   Crash sensor for side airbag: driver side:
   Serial number: 6334MSME482245266
   Crash sensor for side airbag: front passenger side:
   Serial number: 6344MSME4934490DK
5 Faults found:
9440027 - Driver side airbag igniter
          B100B 1B [137] - Resistance Too High
          Error indicator ON - Confirmed - Tested after deleting entries
             Freeze:
                    Status Bits: 00000001
                    Priority: 2
                    Error counter: 1
                    Mileage: 271421 km
                    Date: 2020.01.28
                    Time: 21:05:45
9439771 - Front passenger side airbag igniter
          B100A 1B [137] - Resistance Too High
             Freeze:
                    Priority: 2
                    Error counter: 1
                    Mileage: 271301 km
                    Date: 2020.01.26
                    Time: 13:26:28
Address 17: Instrument cluster (J285) QML file :. 8T0-920-xxx-17.clb
   Software Part Number: 8T0 920 931 D AO: 8T0 920 931 D
   Component: KOMBIINSTR. H33 0253
   Revision: 00100000 Serial number: BYI315V69
   Encoding: 0F05000002000008010000
1 fault:
00003 - Control Unit
            005 - No or incorrect basic installation / adaptation
             Freeze:
                    Status Bits: 01100101
                    Priority: 6
                    Error counter: 1
                    Forgetting Index: 126
                    Mileage: 271301 km
                    Countdown: 0
                    Date: 2020.01.26
                    Time: 11:43:59
Address 56: Head Unit (J503) QML file :. 8Tx-035-1xx-56.clb
   Software Part Number: 8T1 035 186 P AO: 8T1 035 186 P
   Component: Concert3 H03 0310
   Revision: 00000006 Serial number: AUZ5Z6I1238797
   Encoding: 0500048004040100015B070000
   Subsystem 1 - Software Part Number: 8T0 919 603 E AO: 8T0 919 603 E
   Component: Display
1 fault:
03157 - Work restriction due to communication failure
            000 - -
             Freeze:
                    Status Bits: 01100000
                    Priority: 6
                    Error Counter: 41
                    Forgetting Index: 134
                    Mileage: 269230 km
                    Countdown: 0
                    Date: 2019.11.24
                    Time: 10:39:01
             Freeze:
                    Bin.bit: 00000000
                    Bin.bit: 00100000
                    Bin.bit: 00000000
                    Bin.bit: 00000000
                    Bin.bit: 00000000
                    Bin.bit: 00000000
                    Bin.bit: 00000000
                    Bin.bit: 00000000
Do I have to somehow adapt the new seats to the BCM? I'm pretty sure, during the interior switch-up I haven't even touched the airbag sensors, or at least, I've tried not to.
Also, while I'm at it... Does somebody know where I can find the seat plug (red 17pin) connection schema to make the lumbar support operational?
Thanks!
1 - 1 of 1 Posts
