So to all that are thinking of changing the rear discs/pads or both you'll need either OBDELEVEN or Rosstech VCDS.
It's important that you follow the procedures properly! Make sure the car is in ACC mode or ignition is on (engine does NOT need to be on). DO NOT AT ANY POINT ACTIVATE THE E PARKING BRAKE DURING THE PROCESS UNTIL THE VERY END! Or say goodbye to your e parking brake motors, cylinders and the potentially the whole caliper!
If using OBDELEVEN you'll need a battery charger attached to the car. On OBDELEVEN you can navigate to the screen 'Workshop' and then over to 'Brake pads replacement' follow the instructions set!
If using VCDS rosstech you need to go to module selection, go to '03 ABS' and first tap security access and input the 46182 code, once done go back. Toggle your e parking brake ON and then OFF ( foot on brake pedal) once it is OFF then proceed to below:
[Basic Settings - 04]
Select Start lining change mode [Go!] to activate the Basic Setting.
The brake calipers will then open, allowing the pads to be changed. You should hear the rear caliper motors operating. Wait 30 seconds after it says Not Running or the noises have stopped before clicking [Stop]
[Done, Go Back]
[Close Controller, Go Back - 06]
Replace rear pads/discs as usual
[Select]
[03 - ABS Brakes]
[Basic Settings - 04] Select End lining change mode [Go!] to activate the Basic Setting.
The brake calipers will then close. Wait 30 seconds after it says Not Running or the noises have stopped before clicking [Stop]
[Done, Go Back]
You will need to then scan modules and wipe the fault codes.
You're done and set!
~Alex
[Done, Go Back]
[Select]
[03 - ABS Brakes]
[Done, Go Back]
~Alex
