After a few ours of search i found Where the rattle from behind is coming from, when you open the hatch behind left tail Light theese flaps are here and they make the rattle at 1100 Rpm only how do it stop it? What is Those flaps
177759
If it's vibrating, you could always put some felt tape. That is what Audi tries first whenever something vibrates/rattles.
They are just rubber vent flaps to release pressure in the boot when you close it.
The felt tape (or equivalent) is a good idea to fix the rattle.
Don't remove the vents though! If removed i believe water will be able to flood the boot (coming up from road). For examples of these vents failing and letting water in, see Ford Focus 2012 cars onwards....!
