1 - 6 of 6 Posts
Hello
I have a problem with my a5 2.0 tdi multitronic 2012 facelift. It vibrates a bit (i Will get a wheel allignment tommorrow). But sometimes totally random it pulls to the right its like the it just steers hard to the right by it self. It mostly accours at low speeds and you Can see the Steering wheel turn sharply if you let go. Can it just be the roads?(my steering is very light)
Discussion Starter #2
My steering also gets stiffer when accelerating and betaling dont know if it is normal
it have been checked for fault it had 0 faults
Blimey Nicosa that does not sound very good mate. You need to make a series of checks to get to the bottom of this problem cos your safety is important!! By all means start with the wheel alignment cos that is a good place to start, and of course if your car is left hand drive so you drive on the right then the car will tend to steer right cos the road slopes that way. Good luck!!
I found out Someone tried to steal my 20” wheels and the lug nuts Where loose!! Very scary
That is scary! Could the wheel nuts not have come loose? Have you had any work done recently?
A lot of tyre garages will say to check bolt torque after 100 miles.
Shiiiiiit that is not good mate blimey!!!!!! Did you resolve without death or injury?? I suggest that you connect the mains electricity to your wheel nuts and place a web cam to watch the guys when they come and try again.......
1 - 6 of 6 Posts
