1 - 6 of 6 Posts
Hi, while checking my Audi A5 oil the other day with the 3.2L NA V6 I took off the oil fill cap I found coolant in the oil on the back of the fill cap. I checked the coolant reservoir (it was low) I checked it for air bubbles but didn’t see anything. I got the car around 152k and now has 157k and was fine for the last 4k. Car is never driven rough at all. The oil is still the normal colour and not the chocolate milk it would have been if it mixed fully (Since my car is a 2008 it has the dip stick so I can check it without draining the oil).
I heard that coolant can get into the oil via the intake manifold or it’s gasket failing, if not it would be the head gasket or sure.
Also a weird sound was coming from the engine bay after
Any help would be great to figure out what to do
First thing - don't panic! Easier said than done i know.
On visual examination of photo only, it may be just normal condensation + oil residue. Not head gasket blown.
Things you've said such as oil normal colour at dipstick and no bubbles in reservoir seem good.
How far do you drive the car? Is it a daily motor? Are you driving it far or hard enough to drive out condensation moisture?
At this point i would top up coolant, clean any milky residue you find and observe. A head gasket leak will soon start consuming coolant!
If coolant is disappearing fast and the build up comes back quick then off to a garage for a cooling system pressure test.
Wise words indeed!!! I know that when a head gasket goes you cannot see anything from your mirrors for the cloud of vapour that you are creating, and the oil cap internals look like snow. It is more likely to be a lesser evil I think. You need to take pen and paper and test the car one step at a time and always note what you did and what changed, until you work it out. GOOD LUCK!!!!
Discussion Starter #4
I drive the car around 30km a day, the car has taken a lot of coolant since I last checked everything in November.
Coincidentally I was putting in a RS5 grill when I had noticed this and I already had the under trays off and saw that there was nothing and it was dry so leaks are not a issue. Before it had light streaks of coolant in the oil and only had a little bit so I wiped off the cap and took the car for a drive (around 5-10km) and when I came back that’s what I saw.
Luckily I found a picture of my engine bay from last summer and it shows the coolant level and it is way more than what I have now (I’ll attach both before and after below)
98927E5E-0253-494D-84DA-E110FCF8CCB0.png Before 1E7958C1-0003-4D40-871C-141E5CDED6A3.jpeg After
Check the black cross over pipe at the front of the engine. I just needed to do mine on a 2008 3.2, it was weeping slowly near the flange connection to the head, word is it is really common and on the 3.0T
That is surely not the head gasket methinks....
1 - 6 of 6 Posts
