So I've noticed that whenever my phone is connected via bluetooth the volume settings in MMI revert to a lower state. Even after I have gone in and turned it up, the next time I start the car same problem. Any thoughts on how to save the volume settings? Thanks in advance.
are you setting the default volume levels (audio, nav, phone, etc.) from the MMI? I don't think it saves the volume when you simply just turn it up during a call. I think it reverts back to the default setting as set up from the main system defaults...
press radio or media and then bottom right for sound. There you will get the volume options for the various things. You may need to select volume to get into the menu of options (like how loud should the phone be, how loud the sat nav should be and how low the radio or cd or tv should quieten when sat nav is talking)
