Here is My RR Results.......
Looking at mine now, I NEED to stay above 2000 for Sure and not let it drop below when i'm having Fun !!! and Change up at say 3500 ??
You are little bit wrong. You have no torque under 2000 rpm because of meassurement method - dynamic meassurement.
On the 3-rd graph is seen, that full throttle has been pushed around 1200 rpm, with no air pressure from turbo (but ECU wants pressure). Turbo need time to make full pressure, pressure has risen till 2000 rpm, where it has reached and overstep dessired pressure value, which ECU wants, ECU reduce the pressure and control it (that's why there is "wave" (up and down) of torque values between 2000 and 2200 rpm).
Try to go on 1500 for a while and push full throttle, there wont'be 200 FtLb change in real life between 1500 and 2000 rpm, as is on your graph.
I hope it is understandable with my poor english.
