1 - 1 of 1 Posts
Power accessories like a portable car jump starter on the market usually are inconsistent in showing amperage.
Therefore, many people might wonder about the difference between peak amps vs cranking amps vs cold cranking amps jump starters.
If you’re here, then you are probably looking for a jump starter but confused with the unfamiliar specifications when reading the product descriptions.
Don’t worry because we’re here for beginners like you.
Keep reading to find out what is what and which one you should focus on when buying a portable jump starter for your car, diesel engines, gasoline engines, or cigarette lighter, etc.
Read more: Peak Amps Vs Cranking Amps Vs Cold Cranking Amps Jump Starters
1 - 1 of 1 Posts
