1 - 2 of 2 Posts
Hi can anybody give me the correct size or where I can purchase the torx screw which holds the lock barrel. It’s the torx screw which you have to undo to remove the door handle as mine dropped into the door and have took door card off and still could not find it Thanks
A5 COUPE 3.0 TDI V6 S LINE S TRONIC QUATTRO
Old thread but reply might help someone, Had to remove door panel then remove the plastic cover on the door panel found the barrel screw at bottom of the door, ended up dropping it in the door 2 more times, so lucky I did not buy a replacement as would have to strip the panel anyway.
1 - 2 of 2 Posts
