Oil issue
622 Views 2 Replies 3 Participants Last post by  findalex
Today while I was driving, my Audi said to put 1 quart of oil into the engine. When I checked the oil it smelled like gas.
Should I be worried? I know Audi A5 2.0t B8’s have an oil consumption problem.
is the consumption problem related to gas being in the oil?
My last oil change was about 1000 miles ago.
Hello buddy
Gas in the oil is something different than oil burning. You might want to check for codes for leaky injectors.
Oil burning can be cased by several things. PCV is a big reason. When it is due to the piston ring clogging up due to carbon buildup, then you're looking at an engine tear down to replace the piston rings. That's no fun... and expensive!
