1 - 9 of 9 Posts
car has been in a front end collision,now repaired.
mileage is quite low,but comes up with starter motor fault,the chaps had starter taken off and checked,all is ok with that,wiring seems good too..........any idea why it isn't turning over ? some unit next to the battery has also been replaced.
Thursday,20,February,2020,13:36:50:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WAUZZZF53HA031640 License Plate: 2017 A5 B9
Mileage: 52964km-32910mi Repair Order:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 81 A5
AC BB BC D6 D7
VIN: WAUZZZF53HA031640 Mileage: 52964km-32910miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
29-Left Light -- Status: Cannot be reached 0100
2B-Steer. Col. Lock -- Status: Malfunction 0010
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
AC-Reductant Control -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 AD HW: 04L 907 309 L
Component: R4 2.0l TDI H35 1970
Revision: B1H35---
Coding: 0A254032232405083408
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
ROD: EV_ECM20TDI01104L906026AD_001.rod
VCID: 6C81C64BA60E702705F-8038
4 Faults Found:
5456 - Starter Will Not Turn
P3054 00 [167] - Jammed or Electrical Malfunction
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 52964 km
Date: 2020.02.20
Time: 13:25:33
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 8 °C
Intake air temperature: 9 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 10.900 V
Unlearning counter according OBD: 40
Starter control: terminal 50 acknowledgment-Bits 0-7: 36
Status of starter activation relay-Bits 0-7: 3
Starter control: release conditions-Bits 0-7: 98
Starter control: release conditions-Bits 0-7: 90
Starter control: shut-off conditions 1-Bits 0-7: 0
Number of manual engine starts-Bits 0-7: 0
Number of automatic engine starts-Bits 0-7: 0
Number of automatic engine starts-Bits 0-7: 9
28252 - Coolant Pump 3
P26FA 00 [039] - Air in System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:33
Voltage terminal 30: 11.420 V
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
23416 - Implausible Data Received from ABS Control Module
U0415 00 [167] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
Limitation: accelerator pedal: 0.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
23410 - Implausible Data Received from ABS Control Module
U0415 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W0 927 155 G HW: 0CJ 927 156
Component: 0CK 20TDI RdW H03 0008
Revision: --H03--- Serial number: 0000002027
Coding: 000001
Shop #: WSC 05761 780 00200
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU49.rod
VCID: 43D34DF7EB105F5F945-8016
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071170055001872
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Coding: 0CAA489A10A50A9711A44895007D5292E6A592301208508812 004A4967A549
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 49CF5FDFC93C850F5E9-801C
1 Fault Found:
4522496 - Wheel Speed Sensor; Left Front
C0502 00 [167] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
73 00 83 00 80 00 00 50 00 00
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0090
Coding: 141800295544440D0200010088000000000000000000000000 0000000000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 372B2927AFC803FF38D-8062
Fresh Air Blower Front:
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001367063
Relative humidity sensor in fresh air intake duct:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 4EB94B9880PAG0MUFU02
Rear Climatronic Operating And Display Unit:
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501143E11800CD054587141BAC80B9110B31080000000000 00000020001A810A450122025601
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 025D88F3B48A9657DF3-8056
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 170214 036 0471
Serial number: 00000001702090300234
Coding: 5FC7F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 20314638X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 05 07 2016 00717413
Automatic Day Night Interior Mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE114011723610049
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00305389
Convenience And Driver Assist Operating Unit:
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000212124002
Coding: 000000
6 Faults Found:
65878 - Databus
U1123 00 [009] - Received Error Message
[Brake control module: error value in FL wheel speed]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
average_Voltage_terminals: 11.30 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 7.00 °C
interior_temperature: 8.00 °C
Vehicle speed: 0.00 km/h
Terminal control-Terminal 75 status: On
Terminal control-Terminal 15 status signal: On
Terminal control-Terminal 15 via CAN: On
Terminal control-Term 75: qualification: OFF
66672 - Control Module for Light Activation/Adjustment; Left
U116E 00 [009] - No Communications
[Left LCM: no signal/communication]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
131348 - Databus
[Brake control module: received error value in signal ESP_FL_wheel-speed]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
196750 - Databus
[Brake control module: received error value in signal ESP front left distance pulse]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
196754 - Databus
[Brake control module: received error value in signal ESP front left wheel speed]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
196758 - Databus
[Brake control module: received error value in signal ESP system status]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0106
Serial number: 003UP003HF5C
Coding: AACCF0C00C800000585400F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006015
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4CC166CBC64E902765F-8018
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 442 061 403 17
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00AD20D80F383FH
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 442 061 403 17
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00AD20D80F0F3AH
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 102 17
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700102A53DC58758
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 302 17
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700022A55169D7EC
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 442 0C1 603 17
Component: FrontSensor_D 1C5 014A
Serial number: 35575009B21E6005D2BD
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C1 603 17
Component: FrontSensor_P 1C5 014A
Serial number: 35675009B21E6003C299
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 303 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500102A4CE1978A9
Coding: 2D2D2D
4 Faults Found:
9735443 - Pedestrian Protection Crash Sensor 2; Driver Side
B148D 13 [137] - Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52964 km
Date: 2000.00.00
Time: 00:00:00
9735699 - Pedestrian Protection Crash Sensor 2; Passenger Side
B148E 13 [137] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52964 km
Date: 2000.00.00
Time: 00:00:00
9682162 - Multiple collision brake
B13BC F2 [137] - No function
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 22
Mileage: 52965 km
Date: 2019.08.26
Time: 20:57:16
1049349 - Databus
[NWD: 0x103 ESP_03 error value ESP_VL_Radgeschw]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B5E423E842BAF7E3B-8022
1 Fault Found:
4203520 - Databus
[Fehlerwert Raddrehzahlen (ESP_03)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W6 920 971 HW: 8W6 920 971
Component: TDIeGB H09 0523
Coding: 24A440D6288006000120E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU49.rod
VCID: 015F87FFB18C8D4FC69-8054
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 8W5 907 468 D HW: 8W5 907 468 C
Component: Gateway H30 0308
Revision: 5A010004 Serial number: 0485A023717318
Coding: 03010001000086404107000000590012481000070000000001 75078E10000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4ACD60D3CC3A8E17573-801E
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170310205717 22227
1 Fault Found:
66567 - Local Databus
U1030 00 [009] - Electrical Malfunction
[LIN_1_Electric_Error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:20:22
Address 29: Left Light
Cannot be reached
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000056901007
Coding: 8800000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 323D183344AAE6D70F3-8066
1 Fault Found:
13637378 - Databus
[Errorvalue ESP_Wegimpulse]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: not activated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: On
Clamp 15: On
Clamp 15 Status: valid
Remote Start: not active
Driver door: Open
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd false
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
UBat internal: 10.7 V
UMotorBridge: 5.9 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition not met
Lock condition clamp 15: Condition not met
Lock condition E2E clamp status: Condition not met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition not met
Lock condition E2E vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition not met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition not met
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
Component: LCM_MLBevoH05 0024
ASAM Dataset: EV_LCMRightHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW48.rod
VCID: 77ABE927EF48C3FFF8D-8022
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W0 959 593 E HW: 8W0 959 593
Component: TSG FS 005 0057
Serial number: 0000246757509
Coding: 001FCA625001000000001482
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
1 Fault Found:
196660 - Motor for Window Regulator
B1487 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41DF47FFF10C4D4F869-8014
2 Faults Found:
17664 - Databus
[KFC_ESP_22_SNA]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Expanded ambient data 1-Engine running: Engine_not_running
Expanded ambient data 1-Supply voltage: 0.00 V
Expanded ambient data 1-Temperature: -70 °C
Expanded ambient data 1-System status: 4
Expanded ambient data 1: 00
Expanded ambient data 1-driving_direction: 0
Expanded ambient data 1-KFA: 0
Expanded ambient data 1-KFC: 69
Expanded ambient data 1-Ready_To_Drive_Bit: 0
Expanded ambient data 1-StartStop Info: 0
Expanded ambient data 1-Steering_Angle_Calculated: 5 °
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
Expanded ambient data 1-Steering_torque: 0.00 Nm
Expanded ambient data 1-Steering_Torque_Sign: 1
Expanded ambient data 14-KFA_FAST_RESET: 0
Expanded ambient data 14-KFC_FAST_RESET: 0
Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 11.33 V
Expanded ambient data 14-Voltage_terminal_30_unfiltered: 11.53 V
28160 - Databus
[KFC_ESP_03_SNA]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Expanded ambient data 1-KFC: 110
Expanded ambient data 1-Steering_torque: 0.10 Nm
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 CB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0344
Coding: 013500002F9100406309A0000600080231020010004306502F 04000000040030001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7EA5FC03C072F2B7BBB-802A
Sensor For Anti Theft Alarm System:
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1704434E2
Alarm horn:
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000068981928
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 8W0 959 592 E HW: 8W0 959 592
Component: TSG BFS 005 0057
Serial number: 0000247801165
Coding: 001FCA225C01000000001480
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: 4BC365D7C340971F6C5-801E
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8W0 035 192 G HW: 8W0 035 192 A
Component: MU-HS-LND-EU 045 0191
Serial number:
Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP.rod
VCID: 3A2D30139CDA1E97C73-806E
Data medium:
Subsystem 1 - Part No SW: 8W0 919 866 M HW: -----------
Component: ECE 2017 --- 0024
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8W2 919 604 HW: 8W2 919 604
Component: AU49x_DU_STD H40 0008
Serial number: AUZ8Z9GBH00V1E
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
Component: ControlUnit_B H22 0134
Serial number: APVAK121021700020061
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31270391200000
Coding: 0610
ASAM Dataset: EV_DeckLidCONTIAU736 001014
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 48C95ADBD2367C07417-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 L HW: 8W2 713 041 J
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170313001576
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736.rod
VCID: 3D273B0F8DF429AFE21-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 HW: 8W6 907 217
Component: BVS H14 0042
Coding: 0404090300000403024023A0A50000FC00F0C020C000
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 7F5B0107C778FBBFB0D-802A
4 Faults Found:
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
Control Module temperature: 15 °C
Voltage terminal 15: 11.40 V
1123171 - Databus
[ESP_03_ESP_VL_Radgeschw]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
1123960 - Databus
[ESC_Bremsdruckgradient]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0005
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 3039123B4AA6D4C7797-8064
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 8W0 959 595 E HW: 8W0 959 595
Component: TSG HFS 005 0057
Serial number: 0000247429878
Coding: 000FC8220001000000001080
ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
VCID: 4EC56CC33052A2370BB-801A
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 005 0057
Serial number: 0000247426770
ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 176BC9A7CF0823FF18D-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 01:45, VBatt start/end: 11.3V/11.2V. VIgn 11.2V)-----
Blimey mate that is one hell of a list!!! I guess that you need an expert INDI with a complete VCDS system and alot of patience. When a car is involved in a smash the ECU stores loads of stuff some of which may be useless but of course some will be useful for future repairs. Until every last message is solved then you will likely not be able to restart the car. GOOD LUCK!!!
Cars started now.
Lots of faults on it like passenger and drivers crash sensor, steering wheel light, airbag lights (no airbags were deployed) sometimes steering light disappears and steering is light then within a couple of minutes, its back on again.... Cant do another full scan because when it starts scanning its all good until it gets to rear light then scans no further.
Ok well done. So you now need to go slowly and point by point in order to understand what each error message means...
Discussion Starter #5
Nearly all say... Data message missing or missing information,something on them lines, im thinking is it the crash sensor faults front passenger and drivers side, although car was hit driver side front corner
Discussion Starter #7
New crash sensors fitted today, will new ones need coding or will just clearing faults do the trick?
Audi 2018 S5, 2007 3.2 TT, 2010 A5
i rebuilt a B9 S5 that had a front end crash, the sensors dont need programming (and as long as they arent damaged they shouldnt need to be replaced, and the fault codes wouldnt stop the car from turning over. you said something near the battery has been changed, there is breaker on the the battery that isolates the engine in a crash, it need to be replaced and i'd suggest audi for the part (i bought an ebay one and it lasted a week before failing) also this "breaker" wont come up as fault code if not working and the car reacts like there isnt an issue other than it wont turn over. to test this you can jump the car (using a battery pack on the front engine bay jumper points) and the car should start ok, dont drive it like this, or run it for long as the fans and cooling is compromised without the battery breaker
also just a thought, was the airbag ecu reset after the accident as the faults may be historic from the crash and may not clear after you've changed the sensors until the ECU has been cleared?
1 - 9 of 9 Posts
