1 - 1 of 1 Posts
Can't start my a5 3.0tdi 2010 anymore.
First time I was thinking is starter relay , I try jump cables and relay bypass but still no luck.
With diagnostic I can see all modules ( wich are working ) but not the main ECU.
Any diagrams with ground cables ? Or other suggestions please ?
This is the report I got from mechanic
Found the following fault code/s:System : Central electronics system - 18F / Centr.electronics III 3.1 Status :0522 - Engine control unit. Error Message : No signal. Error static. Status :0214 - Power supply. Error Message : Less than minimum. Error Boosted battery. Non start, various electrical faults. No signal from engine ECU. Suspect no power from main relay.
1 - 1 of 1 Posts
