1 - 15 of 15 Posts
In previous Audi's they had this button, called "econ" which would run the heat in the car for 30 minutes even after the car had been turned off. To keep the cabin at the same temp as you left it.
I was just curious to see if this feature remain on the A5/S5? i know there is no "econ" button, but perhaps it maybe a hidden feature in the climate control computer.
I did do a search, and no luck.
You press the AC button and it turns of the AC in the same way econ did.
The old ECON button simply disables the Air Conditioning as this takes up a lot of the engines power to run. By pressing the ECON button, it will turn off the air con and give you better fuel economy.
The a5/S5 does have an ECON button but instead is called AC.
There is no link as far as I am aware between any AC or ECON button and keeping the cabin warm!
I think the people replying to this thread are missing your question completely. The feature you describe is the ability to hit a button and have the fan continue to blow hot air from the engine into the car while you run in to get coffee with the car off. It is in the owner's manual, but I can't remember which button it is. I recommend you do a quick browse for the feature. I seem to remember it being a quick tip or something. Also, search the forum, because I am pretty sure it has been brought up before.
No.
That isnt what Eco does on any other heating system. ECO turns off the air con unit and turns the heating system into an old fashioned style blower.
I have heard of a similar system to what you speak of but that is something different to the economy button on the heating system.
No.
You are right, ECON does excatly what you are saying when the car is running and it can be accomplished in our car's by hitting the a/c button when auto is engaged. However, this wasn't a question about ECON functionality, it was a question about the ECON button and a convenience feature that was tied to it in previous AUDI models.
After he shut the car off in a previous AUDI, he would press the "ECON" button, and it would continue to run the FAN in the car blowing the residual heat of the engine into the car so the interior wouldn't cool down as much. He is confused since our car's don't have a button labelled ECON anymore.
What would be even better is an ECON button that cuts power and fuel consumption by shutting off a user-choosable number of cylinders. This will come in very handy when you are stuck in traffic.
ragazzi,
I think this is what you are speaking of? In the Owner’s Manual there is a section called “Turning the climate control on and off” (p. 98 in the US manual). After the “Tips” icon it states:
“With the ignition turned off, you can activate the residual heat function by pressing the “OFF” button. The residual heat from the coolant is used to heat the vehicle interior.”
I like the fact that if you have the AC on and punch it from a stand still, the AC temporarily switches off to save engine power. :) (p. 96 US manual)
ragazzi,
Do you have pics of your car? That blue looks sexy.
To the other guy that asked for the cylinder shut off, I couldn't agree with you more. It seems like a really easy thing to do in software. Also, while they are in there, a higher 6th gear would be great. I find 5th gear to be useless, and 3k RPM at 75 is ridiculous in a 354HP V8, unless I was towing a boat. In my opinion they should either shut off cylinders or make a taller 6th.
I find it to be rather good. Driving though the peak district earlier in the year (lots of hills and bends), 5th gear was able to handle the range easily.
However, like you I do feel that 6th and 5th are too close to each other
I'm really missing the old 'clockwork' windows the old 80 had too.........
1 - 15 of 15 Posts
