1 - 7 of 7 Posts
I'm looking for a new set of wheels for my A5, but the only option I have is 20"x8.5 because the next option after that is 20"x10 and I think 20"x10 would be too wide and the car would look ugly. Should I go for 20"x8.5? my friends told me 20"x8.5 would affect stability and etc. What's the ideal size for A5
You can go 20X9 or 20X9.5. You have all sorts of options.
Do you already have your car?
Yeah, I've had my A5 for months now.Anyways, I've decided with the 20"x10, would this fit on an A5? what should be the appropriate tire size for 20"x10? What effects would 20"x8.5 have on the car?
Thanks, Sorry I'm not very good with cars & mods.
What is the wheel offset for a non S-Line 2008 A5? All the websites I went to recommend 35mm but I saw some wheels with 25mm and 38mm on the same website, would 25mm and 38mm be ok? I'm also wondering if the car could take 20"x9.5 for both front and rear.
20 x 9.5 will be fine, I have wheels this size with ET36 offset and 15mm spacers. There's a football field of room in those wheel arches!
Have you had an issue with ride comfort, vehicle stability and etc? I just realized that the 20"x9.5 I was looking at is actually for A6 but the bolt pattern is the same as A5's 5x112, the only issue is the 38mm offset....not sure if I should go for this one or choose the 20"x8.5 PCD 5x112 and 35mm offset (the one that's meant for use on A5)
Thanks for answering my questions!
1 - 7 of 7 Posts
