1 - 20 of 95 Posts
NEW - MAPS Audi 2018-2019 6.27.2 8R0060884FK
For MMI HN+ and MMI HNav
Hello board members I am offering here the latest maps for the above mentioned MMI-Systems.
MAPS:
Download Links hosted at MEGA.NZ for each System here.
https://mega.nz/#F!ge5ziYhb!_I1jkXH97ePKGNL6-7yKsw
Alternativ Links Hosted at Uploaded.net and Share Online (Mega.nz TEXT-FILE) here:
HN+:
https://mega.nz/#F!UPRzmIKI!TokHJJ8X513WvOHCf1ASrA
Hnav:
https://mega.nz/#F!BPI1VYKD!UqksKde4z_lkszQXui8LEg]https://mega.nz/#F!BPI1VYKD!UqksKde4z_lkszQXui8LEg
[/URL]
Firmware Archive MEGA.NZ here:
https://mega.nz/#F!MDwBhKpI!tD-tyj1MxEdoPAdAlExSYw
Activators:
The Activators for each System are included in the corresponding MAPS-Packages.
Post in behalf of @alleshateinende
Great work!
All with 3g and 3g plus
Wysłane z mojego LM-G710 przy użyciu Tapatalka
Did the update this morning at work.
Took about 2-3 hours from start to finish with no problems.
Just inserted the SD and ran the update, no issues with not deleting old maps, didn't even need to activate.
Again thanks to all who makes this possible,
Links are inside of the txt files.
I also updated the firmware and maps in 2012 S5 and all worked perfectly. Map update took a bit over 1h and no activation was needed.
Huge thanks to the uploader :)
Discussion Starter · #14 ·
Only for european cars, firmware close to 0,6 GB maps packed 16 GB.
Mega.nz Links have been deleted at MEGA due to Copyright violations.
I am uploading again to MEGA.NZ , Lukjod will update post 1 once everthing is again Online.
In the meanwhile pleas use alternatively Uploaded.net or Share-Online.
Hi..
I have updated my maps to the newest maps 2018/2019. I have Audi A8 from 2013. I have the latest firmware. It was activated before. Last night when i updated my HN+ maps to 6.27.2 i cannot used, When i try to insert a destination to go, my satnav does not calculate the distance anymore. Is there any possibility to fix this issue? Could you please send me more details on my email? Thanks a lot.
Have you driven the vehicle around yet for the gps to fix your location?
Hello. I updated maps succesfully, but cant activate them. I put activation script and folder in to SD, put it in the car and nothing happens. But maps are blocked.. Any ideas?
My car info:
A6 C6
HNav_EU_K0257_6_D1
1 - 20 of 95 Posts
