So I believe right now I would need to go in green screen and check if there's an option for Audi connect and Google earth.
If not, then I need to update the firmware using EU package (mine mmi is RoW), and while installing, I need to check the option for Google earth.
Is the the right approach?
This is from another forum which is same process I completed.
In the green (hidden) engineering menu under /config set "Install Fair Mode". This will enable the dhcp server and DLinkReplacesPPP via USB. Under /diagnose/coding/internal_modules_1+2 deselect all the "online" choices.
For googleEarth it has to be installed but you can check this in green screen.
I don't know about firmware for you as I say I'm in UK, attempt a firmware update using your region. You don't have to update you can just see what it'll install and if 'GEMMI' is listed then install it an you'll not new European firmware.
