New battery, coded VCDS problem
892 Views 0 Replies 1 Participant Last post by  Rhodesia1
Hey all
I just replaced my battery with a OEM one bought from Audi.
The VCDS coding (was accepted (test was ok when values checked and new values are storied) but the status indicator only shows 10% in the MMI?
I had to code through 19 then 004 because 61 wasn’t available/installed in my car.
VCDS coding
When I turn the car off it says the battery level is low and will charge while driving, also that I need to start engine or MMI will shutdown in 3 minutes.
The battery was just replaced today and I’m wondering if there are any other things I may have missed when coding the replacement battery, any ideas?
1 - 1 of 1 Posts
1 - 1 of 1 Posts
