So I wanted to redo the dynamat (actually an equivalent called SecondSkin) on the underside of my rear deck. I took the time to pull off my previous attempt and then get a new sheet on, pressed much more neatly this time. I was quite proud of my effort.
.. that is until the sun went down and the next time I opened my trunk it was completely dark. I had accidentally covered up the courtesy light.
Needless to say, rather than peeling it all off, making a big mess, and doing it over, I'm hoping to just cut out a rectangular window to expose the light. Problem is I don't know precisely where to cut that window, and I'm hoping someone can share a pic so I know roughly where to aim......
Not sure if this is any help, maybe you can use the hooks as a reference point.
The light is located offcenter, on the right side of the deck.
I measured the light to be 25 cm from the back of the rear seats, and 30 cm to the left of the right upholstery.
Perfect, thanks! Finally got a round to 'fixing' this.
Supra are you going to buy an exhaust?
Most definitely, just weighing out which one to buy and squaring away taxes first.
