Can anyone tell me whether or not you can have the navigation system constantly show a map of where you are driving i.e without you actually navigating to a particular destination?
Yes you can AMAN !
Yes, if you select Nav and then the bottom right button of the 4 around the rotary MMI controller, you get the map. Once in this, then the MMI rotary button zooms you in and out. Press the MMI button in and you can then chose various other options - North up or car's heading up, change the scale or move around the map (although this isn't that easy to do - it's either up/down or left/right at one time, so moving around the map to find somewhere like you would with a paper map is not great).
