Carrying on!
With the pump all hooked up I could start routing the rest of the wiring and the water meth lines themselves. I opted to use the headlight washer hose seen as it was in the vicinity and it saves me tapping into the washer fluid tank creating more work. I hated the headlight washers making a mess when they spray anyway so this way was a win win for me!
Secured the AEM hose to the headlight washer hose with a bit of silicone tubing and clamp to get a tight fit.
All hooked up, I ran the hose back up through the nearside fender and across the bulkhead. Also took the time to tessa tape all the wires for a clean OEM look.
When it came to the nozzle the only real option was in the air intake hose before the supercharger which is a little unorthodox but the V6T boys still seem to be getting decent gains from the same location. I had to revert back to the OEM intake hose as I haven't figured out a good way of getting a clean cut through the silicone, I tried with different drill bits on a spare bit of silicone hosing that was laying about but it ended up looking like a 12 gauge had went through it lol. 🤦♂️
