1 - 8 of 8 Posts
Afternoon all.
So yesterday I jumped in the car and it started lighting up like a Christmas tree.
I got a sequence of errors appearing and wondered if anyone has had the same issue and that it might all point to one fault.
Errors in order :
Stabilisation programme and ABS fault See owners manual
Parking brake malfunction!
Headlight range control defective!
Along with refill washer fluid....which I think I can resolve myself haha.
Thanks for any advice.
I will get a VAG tester on it and see what comes up. Seen a few suggestions elsewhere suggesting ABS/speed sensor on the front wheels could be the fault so I will get eyes on them over the weekend also.
I'd say it's a battery problem too. Turned out my battery was completely FUBARed due to shitty lockdown/working from home storage/driving habits, replaced it and no further problems except my drivers door auto window winder doesn't work any more despite my resetting all the faults...
You ever done the windows button hold?
Might be out of range and needs to be reset?
Afternoon all.
Errors in order :
I’ve just had similar fault with my 10 plate sportback. It was an electrical fault code for rear drivers sensor. There’s and Audi tsb the wiring harness breaks either at the abs module under the bonnet or going through the inner wing.
1 - 8 of 8 Posts
