Hey, I need some advice. I started the motor mount replacement. I removed all the bolt on the subframe. When I follow the manual they do not give enough infos apart from remove the bolts.
My issue is the clearance space to get the mounts out. The subframe does not drop enough as it is now. Also the engine is supported above, but when I lift the engine or drop it with the help of the support bar it move the subframe with it, so the clearance space does not appear. Do you have any advice on how to have more clearance? or drop the subframe totally to have enough space to insert the motors mounts?
