1 - 9 of 9 Posts
I was looking it the hidden green menu when i pressed force update. Now my cars mmi system is stuck in an update loop and i have no idea what to do. Is there a way to exit from the loop? Can i press button combination to hard reset? Can i stop the loop with a vcds cabel?
Administrator
You can try a forced reboot. You would have to google the button combination as it depends on your MMI version.
My problem I can’t see anything in screen I can assume when u put the correct file in u don’t need to press anything ?
Is that right ?
Discussion Starter · #9 ·
Thanks so much did you remember which file did you download please I will give it go
I don't really remember i might still have it on a sd card i will get back to you in the morning but what is important if you have a mmi 3 low you should check in the meta info that the version numbers is ending with 3, 4
1 - 9 of 9 Posts
