ozziediaz1969 · Registered Joined 4 mo ago · 6 Posts Discussion Starter · #1 · 4 mo ago Only show this user
DrGER · Registered 2014 A4Q/8K 6MT MMI 3G+ Joined Mar 10, 2021 · 598 Posts #2 · 4 mo ago Only show this user Post the entire history.txt file here inside a "CODE" block, as the optical MOST data bus affects other modules. --g
ozziediaz1969 · Registered Joined 4 mo ago · 6 Posts Discussion Starter · #3 · 4 mo ago Only show this user Here is the file Attachments history.txt 8.9 KB Views: 14
Dippy · Registered Joined Dec 13, 2014 · 1,830 Posts #4 · 4 mo ago Only show this user If it only happened once a month ago it is probably just a glitch. Are there any symptoms?
ozziediaz1969 · Registered Joined 4 mo ago · 6 Posts Discussion Starter · #5 · 4 mo ago Only show this user It happens after the car gets warmed up always
ozziediaz1969 · Registered Joined 4 mo ago · 6 Posts Discussion Starter · #6 · 4 mo ago Only show this user Sub woofer goes on and off
ozziediaz1969 · Registered Joined 4 mo ago · 6 Posts Discussion Starter · #7 · 4 mo ago Only show this user Sounds like the car had a pulse sometimes coming from subwoofer. Even with it off
