Thank you@kmaci27 : The software on your MMI is probably OK -- you don't need to update. You navigation data is quite old. Use the link in the first post of this thread to get the 3G High 6.30.1 update for Europe. Apply the activator script SD only when the MMI says the "navigation database is blocked" (or similar message). --g
Study instructions on first page and all questions will be answered, as you may have a slight language problem try get help in local forum also. Seems that you are not using red menu or you copied only one main folder to the sd card!Hello please help! how to install since i put it on sd card and i am looking for the latest body in the car and after that it says no update! can you help with the installation process?
Hello. I managed to install "6.34.1 2022 MMI 3G High/Plus Europe" on my Audi A6 C6 4F, but the browser tells me "Navigation is disabled".
I have managed to install the activator, and the screen shows me "already installed", but the error continues.
Can someone help me please
Jose
It is very dangerous to give advise in this situation, as we dont know which activator you used and how much have you studied the update threads. Anyhow, i would probably do em update with latest sw and then use proper activator again(in normal situation no need to install map again). Again, regarding activator it is good to follow proper use....just in case to avoid problems and questions after, when people are blaming that activator is s...t. 1. Wake up a system minimum few minutes, wait until maps are blocked, use the script, after script is done, during final restart remove sd.Good morning, someone tells me that the best way is to reinstall the firmware and then the maps with their activator,
Please, can someone tell me which are the latest versions that I should use for firmware and maps? And where can I download them?
Thank you very much.
Thanks Mario, please could you tell me what is the latest firmware and map software for my audi A6 Avant from 2010?It is very dangerous to give advise in this situation, as we dont know which activator you used and how much have you studied the update threads. Anyhow, i would probably do em update with latest sw and then use proper activator again(in normal situation no need to install map again). Again, regarding activator it is good to follow proper use....just in case to avoid problems and questions after, when people are blaming that activator is s...t. 1. Wake up a system minimum few minutes, wait until maps are blocked, use the script, after script is done, during final restart remove sd.
You have the latest sw and map(your display shows).Thanks Mario, please could you tell me what is the latest firmware and map software for my audi A6 Avant from 2010?
I understand that the latest firmware is hnav_eu_k0257_6_d1, and the latest maps would be MMI 3G navigation 6.30.1 Europe, right?
Best regards.
Jose
Hello, I have tried to reinstall the firmware, but the option to start is disabled.You have the latest sw and map(your display shows).
I already told you , you need to make em update(emergency update) and after that use activator.Hello, I have tried to reinstall the firmware, but the option to start is disabled.
I have then tried to execute the activator that appears in this post, and it gives me an error, that the versions do not correspond.
does anyone have an idea?
Thanks.
Jose
I'm surprised none of the 'unix experts' have responded to this issue. You have the correct MMI level and Map level, so you don't need to update them but you have managed to 'mess up' the config file and/or the script file that is used to run navigation by using the wrong one.Hello, I have tried to reinstall the firmware, but the option to start is disabled.
Thanks.
Jose
