I successfully activated maps with this ACTIVATOR, put it on sdcard and wait 10 sec to load it up its same proces like green menu activator.
Ok so I got the maps to install all seemed to go well but now says in blue the navigation data is invalid is there anyone who can help pleaseHELP NEEDED
I have been tryinf for days now trying to update my sytem and having no luck could someone please point me in the right direction.
So i updated to my firmware to K0257 FROM K0206 that went ok then the maps tried installing and it ran through the install in seconds so im guessing nothing happened, can some one please help il send all photos so you can let me know ehat im doing wrong View attachment 179472
View attachment 179473 View attachment 179474 View attachment 179475
what do i need to do first to me it seems like the installed firmware is not correct my car is
Audi a5 sport 2.7d
2011
in my log book file i have a booklet for mmi 3g plus but i think it isnt the correct book can some one help heres my dash
please can some one help me get over what im doing wrong
Dude, can you tell me which folders you activated? Does it work on 6.32.1 8R0060884HQ 2021I successfully activated maps with this ACTIVATOR, put it on sdcard and wait 10 sec to load it up its same proces like green menu activator.
there is seperate topic for youGuys, what about MMI 3G basic without HDD ?
Thank you!there is seperate topic for you
MMI 3G Basic navigation 5.35.2 and firmware updates -...
MMI 3G Basic navigation 5.35.2 and firmware updates - currently 2022/2023 Links to the latest versions of firmware and map update (with activator) Map & activator: MMI 3G Basic 5.34.2 Europe 2022 [Link on Mega] [Activator] MMI 3G Basic 5.35.2 Europe 2022/2023 [Link on Mega] [Activator]...www.a5oc.com
hi Adrian, I have a 2009 Audi Q5 with MMI 3G HNav, can you give me the link to update my maps, thanks2020 maps version 6.30.1 - PLEASE NOTE - this package is ONLY suitable for 3G and not 3G+/3GP so if your firmware version doesn't match the style indicated in the instructions do not bother downloading this file, as it's been cut down to make the download smaller and so it'll fit on a 32GB SD card without issues.
26.99 GB folder on MEGA
The link above includes an activator file, but if you've successfully updated in the last couple of years you shouldn't need it. Note that the activator needs to go on a seperate SD card, and shouldn't be copied with the map files.
For facelift cars with 3G+/3GP see other thread for correct links - don't muddle them up as it doesn't go well.....
Update instruction guide below - this one is a better layout than the one I produced a couple of years ago, and covers firmware updating etc
MEGA
PLEASE NOTE - THESE ARE FOR EUROPE, NOT ROW OR NA and I cannot help with questions about where to find them.
I did not need to re-activate, having done so for 2018 maps. I did still get the SVM error in VCDS, which doesn't stop it working if you leave it/don't have VCDS.
I recommend using JDownloader to grab the links and WinRAR for extracting the archives when finished downloading. If you hit the download limit from Mega and don't want to pay for premium downloads I can recommend using the Opera browser, which has a built in VPN tool so all you need to do is switch location and it will allow you to continue downloading. You do lose the option to use JDownloader if you go that route.
These files are from a variety of sources, so credit due to all those who compile and make available :grin2:
If you don't have up to date firmware, links in the thread below:
MMI 3G navigation 6.24.2 Europe and firmware updates -...
Hi, I think I need to do a recovery, as you do not have any maps installed, the firmware installed and the 257-6-D1, installed with the emergensy procedure, I wanted to know if I have to do all the steps of the firmaware starting from 031 or moved to put 257 directly, thanks[/QUOTE]2020 maps version 6.30.1 - PLEASE NOTE - this package is ONLY suitable for 3G and not 3G+/3GP so if your firmware version doesn't match the style indicated in the instructions do not bother downloading this file, as it's been cut down to make the download smaller and so it'll fit on a 32GB SD card without issues.
MEGA
are you sure you are using the maps for MMI 3G high ?Hello, I ask for help, I am not able to go on with the installation of the maps, I have tried with putting the firmware 0257 back but when I go to install the maps it does only one map-style operation and then masta, help please, thanks
Hi, I have already tried to install 6.25. then 6.25. then 6.31. and then 6.32. and they all gave me the same version of problemare you sure you are using the maps for MMI 3G high ?
and not for MMI 3G+ ?
