Hi bud having problems with my activator, where did you get this, the files look different to the ones linked.
Hi bud having problems with my activator, where did you get this, the files look different to the ones linked.Okay, I finally got it to work.
To be honest, I don't know what made it work this time, but this is what I did:
1. Script files should go directly in the root of the SD-card:
I tried sometimes to have the wrapping folder around them, but that didn't work at all.
2. The car was started without the card in it's slot. I let the MMI boot up while I drove to work (about 20 mins) before inserting it.
3. The car was stationary when the SD-card was inserted.
I'm not sure if the car being stationary was what made it work, but it didn't seem to boot at all when inserting the card while driving.
Thanks for the map and detailed firmware update procedure, @Adrian E!
I used the magnet link for downloading and am currently seeding.
I did properly installed all firmware versions in order and then the maps from this link (26.99 GB folder on MEGA) correctly. All good! However, I have the same problem. I CANNOT activate. The navigation data is blocked. I formatted one of the 2 SDHC cards I got and used for the firmware and maps updates. I then put the activator files as shown in the above image in the root of the sd card. I let the car run for about 5-10 minutes. Then I stopped (Stationary vehicle). Tried loading the activator from the engineering menu. It says 'loading metainfo bla bla..' and then 'Could not read release version' or similar. This is how my sd card root looks like. Any ideas would be greatly appreciated as I am totally stuck and don't know what to do next.Okay, I finally got it to work.
I have exactly the same problem....I did properly installed all firmware versions in order and then the maps from this link (26.99 GB folder on MEGA) correctly. All good! However, I have the same problem. I CANNOT activate. The navigation data is blocked. I formatted one of the 2 SDHC cards I got and used for the firmware and maps updates. I then put the activator files as shown in the above image in the root of the sd card. I let the car run for about 5-10 minutes. Then I stopped (Stationary vehicle). Tried loading the activator from the engineering menu. It says 'loading metainfo bla bla..' and then 'Could not read release version' or similar. This is how my sd card root looks like. Any ideas would be greatly appreciated as I am totally stuck and don't know what to do next. View attachment 178944
can you send me your activator ?Hi bud having problems with my activator, where did you get this, the files look different to the ones linked.
can you send me your activator because i dont have the same ...
I complete all the steps successfully but not luck with the activator. It's been 3 days now and I see the nav screen as "NAVIAGATION DATA BLOCKED". It has and still is causing me great frustration and nervousness. Could please help out. I got the HNAV in my s5 (just to clarify). I copied the following activator files as shown below to a newly formatted sdhc card. It's not picking anything up. Not doing anything when I normally put it in after having waited for the MMI to properly initialize. Also, I tried going to the engineering menu to check whether I could activate/select from there. I tried to but when selecting 'sd1' it tries to read but says not metainfo version found or similar. Could you please help?It worked for me - have you managed to resolve?
Thanks for your quick reply mate! I really appreciate it. I did have the handbrake on and could try without it (that's not a problem).I will give that activator you pasted a shot too. This one looks like it has a '.fsc' file in it which seems hopeful. I ended up in the engineering menu out of despair really. Initially I did it the right way as I explained above. I waited till everything loads in the MMI. Then inserted the newlly formatted to fat32 sdhc card to the unit. Waited..Waited..but nothing. I will give this a try but I am not sure is the right one as I was under the impression that each activator corresponds to a specific map version. This activator looks like is the one for 3gp NOTO 3g high and in the instructions for activation it says 'Please make sure you use the activator that is right for your firmware otherwise in will break your MMI unit'. So, I am not sure that's the right one to safely try. I am really wondering how has everyone else managed to activate using this link 26.99 GB folder on MEGA. I am in a dead-end here. Obviously , don't want to end up breaking the unit completely. I ended up here trusting these instructions would work but now I am at a situation where I have no clear guidance on how to go about it since copying the above link in the root of the sd card clearly doesn't work.From memory you shouldn't need to go into engineering menu to run the activator script. Have you got the handbrake on when trying to do it? I noticed recently that you can't take a screenshot unless the handbrake is on.....
If it still isn't working, try the link in the thread below and see if that makes any difference:
MMI 3G+/3GP navigation 6.31.1 and firmware updates -...
** Thread closed. Please see new 2021/2022 thread here https://www.a5oc.com/threads/mmi-3g-3gp-navigation-6-33-1-and-firmware-updates-currently-2021-2022-europe.176144/ MMI 3G+/3GP navigation 6.31.1 and firmware updates - currently 2020/2021 Links to the latest versions of firmware and map...www.a5oc.com
It's been years since I've activated mine, as once done it doesn't need repeating using this method, so my memory is hazy to say the least!
Do you use an sd card or a micro sd card with an adapter?Thanks for your quick reply mate! I really appreciate it. I did have the handbrake on and could try without it (that's not a problem).I will give that activator you pasted a shot too. This one looks like it has a '.fsc' file in it which seems hopeful. I ended up in the engineering menu out of despair really. Initially I did it the right way as I explained above. I waited till everything loads in the MMI. Then inserted the newlly formatted to fat32 sdhc card to the unit. Waited..Waited..but nothing. I will give this a try but I am not sure is the right one as I was under the impression that each activator corresponds to a specific map version. This activator looks like is the one for 3gp NOTO 3g high and in the instructions for activation it says 'Please make sure you use the activator that is right for your firmware otherwise in will break your MMI unit'. So, I am not sure that's the right one to safely try. I am really wondering how has everyone else managed to activate using this link 26.99 GB folder on MEGA. I am in a dead-end here. Obviously , don't want to end up breaking the unit completely. I ended up here trusting these instructions would work but now I am at a situation where I have no clear guidance on how to go about it since copying the above link in the root of the sd card clearly doesn't work.
sdcardDo you use an sd card or a micro sd card with an adapter?
hello, Can you send the other activator i have same problemI solved the problem with another activator.
helloI solved the problem with another activator.
3G basic goes here:I'm not sure if I understood correctly.. this is not for 3G Basic (A4 2013)?
