All clear thank you. One more question.@kmaci27 : You wrote in a PM:
"When i updated a 3gp of a friend i did dele nav database first from green menu.I read you and u dont see that as a must on 3GHMe deleting the maps first or not does it change anything"
Unless you are changing regions (for example, NAR to EU), deleting the nav database from the Green Engineering Menu is not necessary on either 3GH or 3GP. You can do it, but you gain no real benefit (unless you like sitting around waiting for the MMI to complete this task). If you are updating in the same region, I advise NOT to do this. --g
My advice is to update using a more recent MMI3G release for Europe (like @ware did, above). If your navigation data is NOT blocked after the update, you don't need to do anything. If your nav data is blocked, I advise unblocking with the script I shared in post #303, above. The risk to brick the main unit is low (but never zero) using my unblocker patch, since only one system file is modified to create the unblocker shell commands in /mnt/efs-system/usr/bin/manage_cd. --gCar has 6.17.3 maps. I dont know who updated them before, and what method they used.
I can just install new maps and wait if the navigation will be blocked or not ? If yes just run the bypass ?
What if they used an activator ? Is there any risk to brick the unit or anything like that ?
I will update tomorrow using 6.35.1 and report back.My advice is to update using a more recent MMI3G release for Europe (like @ware did, above). If your navigation data is NOT blocked after the update, you don't need to do anything. If your nav data is blocked, I advise unblocking with the script I shared in post #303, above. The risk to brick the main unit is low (but never zero) using my unblocker patch, since only one system file is modified to create the unblocker shell commands in /mnt/efs-system/usr/bin/manage_cd. --g
Hi, have you successfully updated to 6.35.1? I will also try, but I don't know if DrGER's script works directly with the 6.35.1 update. Many Thanks.6.35.1
I havent had time to do that but ill report backHi, have you successfully updated to 6.35.1? I will also try, but I don't know if DrGER's script works directly with the 6.35.1 update. Many Thanks.
I'll try this afternoon too. I will report my experience.I havent had time to do that but ill report back
Hi all, I have updated to the 6.35.1 map, the process so far went smoothly.I'll try this afternoon too. I will report my experience.
Again, thank you for DrGER's amazing and intriguing descriptions, which he gave for us on many mmi topics.
Thank you, I have looked at post #227, hopefully the information for the sd card will work, in which case i will post it here.See my post #227 above MMI 3G navigation 6.30.1 Europe - currently 2020 for information about my "mmi3ginfo2" SD script, which should give you an idea of what is happening on and inside your MMI3G system with regard to the installed nav database. --g
